It starts for 2 minutes then goes rich anyone know whats going on
I just did a bunch of engine mods to my car. So far when it starts it idles fine and responds perfectly to the throttle. However after about 2 minutes it begins to go rick and begines blowing out black smoke and backfires really bad. I replaced the MAF after I got a code 33 but that didnt solve the problem. My car is an 88 GTA 5.7 and anyone with any info please help.
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Guest
Posts: n/a
I agree. Sounds like when your car is going into closed loop is when the problem is starting. Replace O2 Sensor and then see hwat happens. O2s should be replced every so often anyway.
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
-Bill
Boston Chapter
