What intake gaskets would you use
Old Jun 5, 2007 | 09:09 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
For AFR 195's and a stealthram setup, im just curious what you guys used, or what you would use ? Thanks
Old Jun 5, 2007 | 10:40 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Re: What intake gaskets would you use
I use FELPRO only.
Old Jun 5, 2007 | 10:42 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
what ever AFR recommends.. its either a felpro 1205 or a 1206..
Old Jun 5, 2007 | 10:53 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I believe that AFR recommends the fel-pro 1205.
What does Stealthram recommend?
Just make sure that the gasket matches both the heads and the intake.
The 1205 didn't match my LT1 intake and then I made my own gaskets, it was too close to the coolant ports.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
