Newly installed TPI ..lacking throttle response..any ideas??
Old Jun 6, 2007 | 09:28 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I just installed TPI on my 82 Corvette and removed the carburetor that was on it when I purchased the car.
It runs great other than the fact that it doesn’t seem to respond like I want it to when I punch the throttle.
I had a bone stock 87 Firebird Formula with a 5.7 TPI engine a few years ago and you couldn’t keep it on the road, if you barely punch the gas it wanted to take off on you.
Kind of an in-your-seat reaction when you punched it….these engines are known for low end torque…..
What am I missing here?? Any suggestions on what could be wrong on my car that would cause it to do this? It takes off fine and doesn’t miss or bog down….just doesn’t squall tires or snap your neck like I feel it should. Everything (gaskets, sensors etc) is brand new on the engine.
I'm not sure if the kickdown is working correctly though, I'm scared it may have came unhooked...
Old Jun 6, 2007 | 08:30 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Newly installed TPI ..lacking throttle response..any ideas??
What motor did the TPI intake come off of? If it came off of a 305 then the injectors will not be big enough to fuel that 350. Same goes for the prom. You need a 350 prom. Also i would check to make sure ur TPS is adjusted correctly.
Old Jun 6, 2007 | 08:41 PM
Car: 1971 Camaro
It came off a 305, but my injectors are 350 22lb injectors and the custom prom is written for a 350.
It's a 90-92 style speed density set-up.
I went out and did some digging, I don't think my TV cable was set correctly. It was all the way foward....I moved it back about 1/8".
Hopefully that's what the problem was, because mostly the it wasn't kicking into passing gear. I'm sure that has an effect on take off's from a dead start too.
I wrestled with a miss, high idle, timing ect since I installed this last week...but it's all coming together now....everything else has been fixed...I'm getting excited!
Thanks again,
Dennis
went from this:
To this:
Old Jun 6, 2007 | 11:33 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
SWEET
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
