got a code 33 on the way home tonight
Old Oct 1, 2000 | 06:54 AM
superiroc's Avatar
i put a napa MAF in and it lasts about a month. So know i got another maf from napa and a month later i get a code 33 tonight driving home. Crusing down the freeway it hesitates a little like someone cut the fuel for a second or two and then the ses light comes on immediately for about 8 seconds. It did this 4 times on the way home about 10 miles so i check for codes and got a 33. I'am going to clean the maf connector but i think the maf might be shot again. If i remember correctly a code 33 is MAF right.
Old Oct 1, 2000 | 01:25 PM
rondubbs's Avatar
Originally posted by superiroc:
it hesitates a little like someone cut the fuel for a second or two and then the ses light comes on immediately .
I HAVE THE SAME PROBLEM, IT FEELS LIKE THE THROTTLE BODY BLADES JUST CLOSE, THEN THE SES LIGHT COMES ON.. I THINK IT MIGHT BE MY BRAND NEW BORG WARNER MAF,, BEFORE I GOT THIS EVERYTHING WAS FINE. MY CONNECTIONS ARE FINE AND MY RELAYS ARE NEW.. MY TPS VOLTS ARE ALSO WITHIN SPECS!!!
Old Oct 1, 2000 | 09:21 PM
RP1987GTA's Avatar
ck the maf relays closly ...all of them.I've had new ones right out of the GM box...fail,or intermentily not work..ie bad contact adjustment..causing the problems you describe
87GTA,MAF screens removed,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster,TPS.54,Bosch Plat plugs,base timing 6BTDC,Bilstiens in the rear....,don't let yer meat loaf
Old Oct 2, 2000 | 01:10 PM
rondubbs's Avatar
which relay ,, the maf power or burnoff?? which one would casue the hesitation??
Old Oct 3, 2000 | 10:31 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Also check the connector at the MAF.... I know you said it's fine, but clean the contacts with rubbing alcohol and a q-tip and jeweler's file, or use some TV tuner instead of the rubbing alcohol. That connection there can get quite corroded and lead to an intermittent code 33 as you describe. The best thing you can do is replace that connector, but it's pretty pricey, about $36 at the dealer.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
BumpaD82
Feb 26, 2016 02:57 PM
1MeanZ
Dec 18, 2015 05:39 AM
tyeo098
Nov 30, 2015 06:27 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Ranbo108
Sep 9, 2015 12:20 PM
