I need HELP putting a TPI on a 383!!!!!!
Old Oct 4, 2000 | 02:57 PM
Metallica383's Avatar
Ok guys I know that TPI is definitely your turf till now I have ran carb and I am building a 350 with the older style heads which are 2.02 well i can get a good deal on a 85-86 TPI well I dont know that much thats why i am here so I need some kind of chart to tell me what all I need Is there a good manual that will show me what I need? Is the wiring harness different on the 85-86 than on the other TPI because it dont have a harness and i was thinking of a painless wiring harness.
Thanks for any help
Old Oct 4, 2000 | 09:41 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
First of all, the 85 and 86 TPI systems are VERY different, with different wiring harnesses and ECMs. The 85 harness can be used with an 86 ECM, but there are some repinnings that need to be done to make it work. Stay away from the 85 setup with the old "870" computer, you will also need to buy a Burnoff module which will run you around $900 if you can find it. Go with the 86-90 "165" ECM, my swap from the 85 setup cost altogether around $150 for parts.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
Old Oct 4, 2000 | 10:36 PM
Kevin G's Avatar
A stock TPI setup wont flow enough to take advantage of that 383 your building.
I built a 383 with TFS heads, and I installed a stock TPI on it and it didnt run much faster.... .2 tenths to be exact. i upgraded my TPI to a Superram and it was like night and day. I dont know how much money your willing to spend, but maybe get an aftermarket base like Edelbrocks and some AS@M runners to make some decent H.P.
Old Oct 6, 2000 | 01:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you have a carb'd engine now, and want to switch to TPI, I'd get the Accel Super Ram conversion kit. Its about $3000, but it includes what you need to convert your car to EFI with a SuperRam intake.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
RazorN8
Jan 7, 2022 11:44 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
