need number for edelb. heads
Old Oct 7, 2000 | 09:51 PM
whiterocz's Avatar
whats the part name or number for the edelbroc heads that the factory tpi manifold will bolt up to. thanks
Old Oct 8, 2000 | 09:31 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Well there are a few depending on what year of TPI you have.
If you have an 1985 or 86 then you can use many different heads. If you have an 87 and up, I think there is only one choice, the Performer Centerbolt # 6084. Then again, if you have an aftermarket intake manifold, then it probably allows both bolt patterns, which gives you more options.
Check out edelbrock's site.
There are many good cylinder heads out there, take some time to check them all out.
Mark.
*** I make no claims that the information or part numbers provided in this posting are correct. Call the manufacturer. ***
Old Oct 8, 2000 | 11:48 PM
Jarod87IROC
Guest
Posts: n/a
Actually, the centerbolt performers are part # 6085. I bought mine from www.sallee-chevrolet.com for $999.
87 IROC
350 TPI 5-speed
- Edelbrock Aluminum Heads, LPE 219 Cam, Super Ram, SS Wheels, Graphite Leather, etc. Click here to see the rest.
-=ICON Motorsports=-
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
