Airfoil and other TPI questions
Old Oct 11, 2000 | 12:44 PM
peez's Avatar
1. Is an Airfoil a good purchase and does it really help?
2. I have an 87 formula 350. Can I remove the baffle box and if I do what effect does it have?
'87 Formula 350, Nothing Special Yet
Old Oct 11, 2000 | 04:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its good if you can get one cheap. SLP sells theirs once in a while for $25 Your other ? i have no clue about.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.4@98
Old Oct 11, 2000 | 04:28 PM
rondubbs's Avatar
airfoil is a basic mod,, this is one of the first mods many of us do to our cars, including a K&N filter. get one off of ebay..
what is a baffle box??
Old Oct 11, 2000 | 04:54 PM
TheFormula350's Avatar
Hehe, baffle box is a good name for it. It's Pontiac's dumb@ss idea for an intake. *Very* restrictive. I don't see how you could just remove it (you can't cut slots in the side like newer models), but you can replace it. I'm personally gonna get the SLP cold air box by itself, then find the tubing from an 88,89 car (that's what SLP uses) so I can save some money. Hopefully, they'll sell me the canister relocation stuff separately, we'll see. HTH.
Matt
87 Firebird Formula 350
Old Oct 11, 2000 | 08:14 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
An airfoil is worth 12-20 cfm depending on the throttle body. So if your engine can use the additional airflow, then you can make additional HP.
The air box you are referrring to can certainly use some upgrades. I would at least look at an K&N filter, and perhaps a K&N cone filter and throw out the whole air box.
I made my own coil air kit with some sheet aluminum. Basically isolated the engine bay heat from the air box so it would draw air from the fender. Cheap and it worked.
MArk.
Old Oct 12, 2000 | 07:10 PM
peez's Avatar
The only bad thing about throwing out the whole intake system is that there is a sensor attached and I don't really want to ride around with the check engine light on.
Can't I take the air box(not the filter box) out and hook the two hoses together?
Old Oct 12, 2000 | 07:53 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You can remove the baffle box and hook the mass air flow sensor directly to the throttle body but it will not solve the problem. The problem with the restrictive air cleaner setup on your car is the factory air cleaner body. The 1985 thru 1987 cars had a different air cleaner body then the 1988 and newer cars. If you go to a salavage yard and get the 1988 and newer air cleaner setups you will see a nice increase in air flow. According to SLP the 1988 and newer air cleaner setups are 15% less restrictive then the 1985-1987 setups.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Oct 12, 2000 | 08:37 PM
peez's Avatar
Thanks, I didn't know that. There is a salvage yard here with 7 or 8 1988 or newer firebirds.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
