At what point is it necessary to use a chip>>>
Old Oct 14, 2000 | 01:53 AM
UDO1NUN's Avatar
Give scenarios for both MAF and SD please. What mods can be done without having to get a chip. I want reliability and no surging idle or funny stuff.
Old Oct 14, 2000 | 08:32 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I'm running my stock chip still with the mods in my signature. About as radical as you can get without going to a supercharger.
Idle does surge a little bit, but not a nuisance.
Sparks a flyin'.
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
Old Oct 14, 2000 | 09:39 PM
RP1987GTA's Avatar
stock chips sux ...I did a 100 mile test drive with both a stock 87 chip and a ADS chip i got two MPG more with the ADS chip and a hell of alot better drivablity...much better throttle responce
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Deemax
Sep 12, 2015 06:53 PM
Out-Cast
Sep 11, 2015 08:03 AM
Ranbo108
Sep 9, 2015 12:20 PM
