Code 34?
Old Oct 15, 2000 | 05:38 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Code 34?
I got a code 34(i think thats what it was) a few weeks ago...that code means the MAF isn't getting enough voltage...so i replaced the power relay...scanned the computer...code is still there and my mechanic can't get the code off the computer....i'm gonna check the connections make sure they are clean...but if thats not it what does it mean? Is the MAF fried or is the ECM fried? The MAF is about a year old
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood K&N filter air foil Stage 2 Fastchip B&M Stage 2 shift kit Flowtech shorty headers SLP 3'' exhaust Cams HI-6S igntion with PS-91 coil MacEwen white gauges overlay's SLP rear sway bar Koni's all around and one kick *** stereo!
Rice....it's whats for dinner
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Oct 15, 2000 | 06:10 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Did u mod your MAF??
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Oct 15, 2000 | 11:34 PM
fly89gta's Avatar
Car: 2018 Camaro SS
nope haven't touched it
Old Oct 16, 2000 | 12:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check TPS voltage it should be .54 v if it is to high you could get a code 34.
You could also measure the output voltage on the MAF to see if its fried. I dont remember with connectors ( C-B I think...)or what the voltage should be, but I'm sure someone else here knows it...
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Administrator
Maybe u should post this in Tech/General Engine. Some1 there will probably be able to answer this.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROCZTWENTYGR8 (edited October 15, 2000).]
Old Oct 16, 2000 | 08:35 AM
fly89gta's Avatar
Car: 2018 Camaro SS
the TPS is fine..i checked it the other night...it was fine at idle but was actually a bit low at WOT...so that was adjusted
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
