Experience and/or thoughts concerning TPIS/AFR L98 Heads
Old Jun 14, 2007 | 12:19 AM
Penix's Avatar
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
I wanna know if any of you have used these and for those of you who have, what did you think of them?
Thanks Guys!
Joel
Old Jun 14, 2007 | 07:52 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Experience and/or thoughts concerning TPIS/AFR L98 Heads
I have the AFR's. Can't really tell you too much at this point since I haven't driven the car yet but they shore are purty.
That aside, both of my AFR's weigh in at just 3 pounds more that just 1 of my stockers. All fully assembled.
Old Jun 15, 2007 | 12:45 AM
Penix's Avatar
Are those just the regular AFR's or the TPIS/AFR's? There is a difference.
Old Jun 15, 2007 | 05:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Didn't know there was a difference. I have the AFR Eliminators.
Old Jun 16, 2007 | 08:22 PM
Penix's Avatar
Check them out here:
http://www.tpis.com/index.php?module...AFR+Cyl.+Heads
Old Jun 17, 2007 | 12:11 AM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
wow those are expensive, arent normal afr's like $1,400? How much more power are they supost to make. Normal afr's are good for 60-70 hp right?
Old Jun 18, 2007 | 11:25 AM
Guest
Guest
Posts: n/a
No flow numbers, waste of time.
I personally wouldnt buy anything from them, overpriced.
Old Jun 19, 2007 | 06:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yeah. Anything TPi$.
Old Jun 19, 2007 | 07:46 AM
Abubaca's Avatar
I can't speak specifically about those heads, but I'm leary of anything from TPIS. They do sell quality, but a lot of times it's someone elses rebadged stuff, or just plain overpriced.
That being said, I'm sure they're GREAT heads.
Old Jun 20, 2007 | 04:50 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i think you'd be better off buying some 180cc AFR comp heads than those. thats a lot of money. for the money i doubt that there THAT much better.
Old Jun 20, 2007 | 11:06 PM
Penix's Avatar
I can get a set for just under $1800 shipped from a guy on the East Coast who bought them for his Corvette but wrecked the car before he got a chance to install them.
So it sounds like noone has experience with this exact set of heads, is this the case?
Old Jun 21, 2007 | 05:32 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
No I don't have experience with those heads either. I agree with everyone else as far as to go witha good set of AFR or Canfield heads for the money. You can't beeat their flow numbers and for under 1500 you will never be happier.
Not to totally bash TPIS but their clims for those heads are contrary to popular believe that those heads are worth spending money on due to flow reasons. There is not huge amounts of port room even on the aluminum corvette heads let alone the crappy cast iron heads. The stock intake runner cc's on the vette heads was 163 if I rememeber correctly. They had to do lots of port work to try to open them up and they have an inferrior combustion chamber design. The money would be better spent on a set of other heads.
Old Jun 21, 2007 | 05:37 PM
Guest
Guest
Posts: n/a
He said they were AFR heads that TPIS ported.
They probably flow fine, knowing TPIS but I surely wouldnt pay any premium for it. Do you know if they are the new Eliminator design or not? Might make more sense to put that $1800 towards the new AFR design.
Old Jun 21, 2007 | 06:05 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Yeah if they already got the crazy AFR port job to them ...what can TPiS offer in respects to gains .... doubt it's worth it at all
Old Jun 26, 2007 | 12:30 AM
Penix's Avatar
Okay, so I found out definitively that the TPiS customized AFR 180cc heads do not flow as well as AFR's Competition Package 180cc heads. So to put an end to this post, these heads ARE NOT worth the money! Even if you can get them for $1800, they do not compare to the AFR C/P 180cc heads, which are cheaper too by the way!
Old Jun 26, 2007 | 09:59 AM
HD4mula's Avatar
I got 304rwhp/366rwtq with the Eliminator 180s and bigger intake. Look details here:
https://www.thirdgen.org/forums/tpi/...-tpi-dyno.html
Old Jun 26, 2007 | 07:42 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
No one has experience because no one wants to pay that kind of money for heads you can buy elseware. As said earlier.....mostly just rebadged stuff.
lt500r55
Sep 1, 2021 01:30 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
CRFred
Feb 7, 2016 11:39 PM
gta90
Sep 15, 2015 04:00 PM
anesthes
Aug 8, 2015 09:37 PM
