idling prob
Old Jun 14, 2007 | 08:52 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
idling prob
Car runs funny and when you put in in drive bogs down.why any idears.305 tpi
Old Jun 19, 2007 | 12:05 AM
Shamble's Avatar
Car: IROCZ
Engine: LB9
Axle/Gears: posi
Re: idling prob
I had the same issue a few weeks ago, I would go into changing the inexpensive things first, like cap n rotor, spark plugs and wires. make sure to check the ohm's on all your fuel injectors (should read 16+ for stock 19lb/hr), check your fuel filter ...are you using 92 gas? When does the idle go bad? if its right on startup it could be your EGR and/or FPR which is located directly under your manifold. GOODLUCK !!!
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
customblackbird
Oct 1, 2015 04:30 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
