Need Help fast with IAC adjustment!!!!
Old Oct 16, 2000 | 07:50 PM
fast89's Avatar
I am going through instructions from tech article on adjusting idle but when I removed the IAC and tried starting the motor it would not start. Why will it not stay running??
Old Oct 16, 2000 | 08:40 PM
rondubbs's Avatar
you just unplugged the harness to the iac, right? you didnt take the whole think out?
Old Oct 20, 2000 | 11:37 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Well, if you read the same article I did, I had the same problem... It doesn't tell you to remove your jumper wire before you start the car. There was also a post about THAT - starting your car, driving it, with the jumper wire still in the ADLD(?) with both positive and negative feedback... Anyways, did you take the jumper out before you attempted to start it? Actually I haven't tried again, because when I realized that was probably the problem, I had already gotten sidetracked with something else. I'm gonna go back and try it again today.
Old Oct 20, 2000 | 03:28 PM
Car: '91 Z28
Axle/Gears: 323's
Well, I just tried it, got it started, but can't adjust idle... wtf? The idle stop screw will back out, but the stop on the throttle body won't follow... And it's WAY up there, too - about 1250 rpm's... I posted about it, but if anyone can help me here, please do - I'm all ears... thanks
Old Oct 20, 2000 | 10:13 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
It would help if I knew what year engine we're talking about.
JakeJr
92-Formula
Dec 12, 2015 10:34 PM
86IROC112
Nov 27, 2015 09:54 AM
Lanz06
Sep 14, 2015 07:16 PM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
