What kind of improvements should I expect?
Old Oct 20, 2000 | 01:07 PM
rich1034's Avatar
Well, I've got a plan to outrun the wife's Mustang. The Mustang's best time is 13.68, with me driving, she can only muster a 14.22. I have an 85 TA with free mods, and Hooker catback exhaust. My best time with the 3.27 open rear is 15.24.(all times uncorrected). My question is, with these mods, can I beat her 13.68?
slp headers
3.73 gears
Trans-Go shift kit
2400 stall
slp cold air
pulleys
MiniRam II
52mm TB
24 lb injectors
ported stock heads
afpr
custom chip
MSD 6AL
hypertech coil
summit TPI cam(204/214 @50 .420/.442 lift)
Is this going to get me into the low 13's? What about the cam? good/bad, should I go larger? suggestions please!!!! This is going to be a daily driver, and still have the A/C. All the smog BS is gone already, and will never go back on. Do you see any problems with this setup? Need to get a good combo to start with, can't spend all this money twice, and this is my first TPI car. Thanks for the advice
Old Oct 20, 2000 | 01:39 PM
Kyle F's Avatar
You need to change the cam with everything else you are doing. If not you will be shorting yourself som performance. Then yes you should be in the mid 13's with a little fine tunning and a little track moads you should be able to beat her
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Oct 20, 2000 | 04:34 PM
rich1034's Avatar
Which cam would you suggest?
Old Oct 20, 2000 | 08:20 PM
88TAGTA's Avatar
with the miniram use SLP's larger 224*/230* cam
Old Oct 21, 2000 | 12:00 AM
Ski89Z28's Avatar
I agree with 88TAGTA!
Just a couple of things.
Either port out your intake base or get a aftermarket one. You'll need it!
The other thing is you could get the same low 13's if you stay with the plenum you have and port it and use large tube runners, and it is cheaper. The miniram is usaully better suited for +0.030 engines however it may be ok with a 350 but you'll loose some low end torque but top end rpms has been noted to 6500rpm!
Then there is the superram, you loose a little low end torque and gain some top end ... more suited to a 350 engine unlike the miniram.
The last thing is the 52mm TB having any gains since the NEW 502 BB TPI crate motor came out with a 48mm TB on it. Alot of discussions have popped up about it saying the 48mm TB flows enough air for our engines.
The intake manifold is important but the other things I talked about it is up to you.
Also read the magazine articles on this site especially the "Hard Rock Camaro Part I & II" it may help you. The ZZ9 cam is very simular to the SLP 224*/230* cam but more expensive, stay with the SLP.
Good Luck!
Old Oct 21, 2000 | 12:18 AM
Dan87IROC-Z's Avatar
Yes, I agree, that SLP cam will make that Mini Ram set up one heck of a ride. You should also consider a new set of heads when you have the money.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 21, 2000 | 09:16 AM
Mark 89Formula's Avatar
This is a 305, right? In general the Miniram is not recommended for a 305. I'd steer you towards a large tube runner setup but if you really want a Miniram then you'll have a major league mismatch between intake and heads unless those stock heads are fully ported. A set of fully ported L98 AL heads are a better choice because they come with 1.94" intake valves versus 1.84" with the stock heads but still work with the 305 bore size. My advice is to run a killer set of heads and keep cam intake duration between 215 and 220 degrees @ .050 to retain good street manners with AC. The custom chip will compensate for the 24 lb injectors which are overkill on most 305s. Finally move up to a 2800-3000 RPM stall converter to compensate for the low end torque loss with the Miniram.
89 Formula 350, Accel Tri-Ys, 3" SLP, chip, Jacobs, SLP cold air, Probuilt tranny, Vigilante, 3.27s, Spohn torque arm & LCAs w/brackets, GW Subs
F-body-fan
Jan 12, 2023 01:49 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Gunner242
Dec 25, 2015 04:49 PM
wanext
Oct 6, 2015 12:18 AM
hartsmike
Oct 2, 2015 07:11 AM
