Speedo/VSS Problems
Old Jun 18, 2007 | 10:09 AM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
Speedo/VSS Problems
So a few days ago I fired up my car and left my school's parking lot when I smelt a horrible buring plastic type smell and all of a sudden my speedo stopped working.
Just yesterday I had the car jacked up to change the sparkplugs and I checked the VSS to see if it got damaged somehow and it looked ok and I also checked the wiring and fuses and everything looked ok.
How do I tell for sure that the VSS burnt out out on me? The part shop said it would be $120 and I'm not dropping that kind of money if its not broken.
I was also thinking that maybe something shorted in the gauge cluster itself but all the other gauges work just fine.
The car in question is a 1992 Z28 with a T5
Old Jun 18, 2007 | 11:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Speedo/VSS Problems
Its a 10mm bolt holding the speedo gears in. Remove that, pull the speedo unit out, and look at the gears. One is on the speedo unit, the other is on the tailshaft inside. Use a flashlight to see it.
Old Jun 19, 2007 | 11:10 AM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
I didn't check the gear in the tailshaft. If it is that would a replacement be hard to come by?
Old Jun 19, 2007 | 11:50 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Also check the VSS buffer box, its located under the passenger side dash, little yellow plastic box. it could have shorted and burned.
Old Jun 19, 2007 | 11:37 PM
Kevin91Z's Avatar
There is no yellow buffer box on 90-92 TPI cars. That's only on 86-89 MAF TPI Firebirds, and 88-92 TBI cars.
Old Jun 20, 2007 | 01:13 PM
AC's Avatar
AC
Car: Used to drive a camaro
Hot92z, I found a really good site for ordering speedo gears...check my post:
https://www.thirdgen.org/forums/tran...do-sensor.html
Old Jun 21, 2007 | 09:42 AM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Cool thanks alot. Hopefully this weekend I have the time to inspect everything is detail.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
