ok next item
Old Oct 23, 2000 | 08:16 PM
88FormulaWS6's Avatar
ok next item
what should i add next to improve performance.....thanx for any responses
88 Firebird Formula WS6
305 TPI 5 speed
B&m Ripper shifter
MSD Blaster coil
TPIS airfoil
Hypertech fan switch
TPIS 170 degree thermostat
3 inch flowmaster exhaust
alt +crank pulleys
....times to race and see
Old Oct 23, 2000 | 09:00 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
From what I have heard, and what I plan to do next is porting out all intake componenets and make an afpr. Possibly a walbro fuel pump. Then, maybe just a little head work, cam and headers.
Then, I'm done. That's enough to put into this car. I have another that needs some love and attention.
Only problem is anytime that something breaks, I go ape shiit and want to replace everything with aftermarket goodies. My car has been leaking out the back out the intake for years now, but I can not justify ripping it apart w/o, again, going ape shiit.
I do not see a hi flow exhaust in your list. Maybe a nice dynomax flowmaster if you like their sound better. Plus a cheap hi-flow converter.
Before you get to torquey, tie up the frame before you start seeing cracks in your roof! ... if you have not already.
Later,
Mike
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Old Oct 23, 2000 | 10:45 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
My mods and times are in my sig, if you have questions e-mail me.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Oct 24, 2000 | 12:13 AM
rondubbs's Avatar
check out my mods.
on a 305 you DO NOT NEED bigger runners or intake. just port your plenum, no need for an afpr either.
1988 GTA Trans Am 350tpi: 42k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, ignition module, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, flux capasitor
Old Oct 24, 2000 | 02:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All cars can benefit from an adjustable fuel pressure regulator. And a 305 will benfit from port-matching your intake manifold, runners, and plenum, too.
For the original poster, I'd add some SLP 1 5/8" headers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
F-body-fan
Jan 12, 2023 01:49 PM
Magman
Aug 2, 2016 08:32 PM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
e3pres
Sep 9, 2015 01:51 PM
