Fuel pressure and miniram
Old Oct 24, 2000 | 08:01 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
What is the stock fuel pressure for a 88 TPI 350? And what is a good cam to run with the miniram? I will be getting one soon and I want to do the cam at the same time.
James
If the women don't find you handsome they should at least find you handy
Old Oct 24, 2000 | 09:43 AM
theformula's Avatar
I'm not sure about your year, but mine was 42pounds with the vacuum hose connected.
Go with the TPIS ZZ9 cam. http://www.tpis.com
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
Old Oct 24, 2000 | 02:15 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Although the ZZ9 cam is a good cam it is very much overpriced. Check out the Comp Cams Xtreme series. Internet Racer's Supply can have these cams ground on whatever LSA you want. I am running the 218/224 CC Xtreme cam ground on a 112LSA. This is a good cam to use with a semi-siamesed large tube runner setup. It makes good power (check the signature). However, now that I have a MiniRam I would like to run the CC Xtreme 224/230 cam. The 224/230 cam is a very good cam for a MiniRam motor. But, make sure you have heads that can flow REALLY well or the cam won't work as good as it can.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 24, 2000 | 03:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Well there is one in the classifieds right now. But I dont really want to spend a lot of money at this time on a cam. Trax how much are the ones your are talking about? I wont be getting heads until early next year so I just want something better than stock.
James
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
