Whats the stock fuel pressure?
Old Oct 26, 2000 | 12:55 PM
Jas89TTA's Avatar
Whats the stock fuel pressure on a 87 Trans Am TPI? I have a Holley AFPR I'm installing on my 350 TPI and what to start abouve what the stock setting is. Also when setting FP the hose is disconnected and then adjusted to say 45psi and then connect hose correct?
Old Oct 26, 2000 | 02:22 PM
'89Formula305TPI's Avatar
I can't remember the stock settings, but that is the way to adjust it!
'89 Formula 305 TPI T-5
Check out my car HERE!
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I believe the stock pressure is somewhere around 42-45 PSI. 45 PSI is a good place to start. Its all a matter of trial and error until you find the pressure that works best for your car.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 26, 2000 | 02:55 PM
rondubbs's Avatar
stock psi is not the same for every car. it is between 42 and 47psi
Old Oct 26, 2000 | 04:26 PM
Fredrik's Avatar
According to TPIS the stock setting for a '87 ta is 37-43 psi. It was changed in '88 to 42-47 psi so there can be a good idea to raise the fuelpressure to around 45 psi.
/Fredrik
Old Oct 26, 2000 | 05:11 PM
RP1987GTA's Avatar
stock setting on mine is ....37 at idle with vacuum hose connected......47 at idle with Vaccuum hose disconnected.This is with the engine warmed up and running.
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
