Need to know what new setup will do
I have a 91 GTA with superram intake (ported), edelbrock lower intake (ported), 58mm tb, comp cam xtream cam w/.495-.502lift, trick flow 23*, crane gold 1.5:1 roller rockers, 1 3/4 SLP headers (no AIR), SLP 3" catback (no cat), the block is the stock 350ci. Thanks
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
1987 Buick Turbo-T
Get a custom chip, properly adjust voltage and iac,play w/fuel pressure, hit the track and you may see 12.5
Good luck. Tell me what you get.
"Ever notice how imports sound like weedwackers"
adjust fuel pressure, adjust iac and voltage, get a custom chip and some sticky sneakers, you may hit mid 12's. Good luck. Tell me what it does.
I guess I forgot to say I have a custom chip. Sorry about that. A 12.5 you say. What MPH can I get?
1987 Buick Turbo-T
1987 Buick Turbo-T
LT1Formula
Oct 8, 2015 08:34 PM
