code 34?
Old Oct 30, 2000 | 08:31 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
code 34?
whats code 34?
Old Oct 30, 2000 | 09:52 PM
rondubbs's Avatar
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor),
you have a maf not a map sensor. check your connections at the maf sensor and at all of the maf relays. .also check your tps voltage.
Old Oct 30, 2000 | 11:39 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
can a bad burn-off relay cause this?
89 GTA
Rice....it's whats for dinner
The left lane is for passing...if you aren't passing get the f*ck out of my way!
Proud memeber of the South Jersey Fbody Crew(all 2 of us!)
http://www.hometown.aol.com/clarkemustgonow
Tony
Old Oct 31, 2000 | 09:11 PM
fly89gta's Avatar
Car: 2018 Camaro SS
anyone?
Old Oct 31, 2000 | 11:05 PM
Hawaii5.0's Avatar
A bad burn off relay will cause code 36 to trip. That is what mine is doing right now, will post results of my troubleshooting later.
Old Nov 1, 2000 | 11:15 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
How do u test your TPS voltage?
Old Nov 3, 2000 | 08:25 AM
fly89gta's Avatar
Car: 2018 Camaro SS
ok what if the TPS is adjusted fine? Time for a new MAF?
Old Nov 3, 2000 | 12:57 PM
rondubbs's Avatar
88blkiroc , to test your voltage you need a digital voltage meter. https://www.thirdgen.org/newdesign/tech/tpimod2.shtml this link will help.
fly89gta, if the tps is fine and all the connections are CLEAN.(use alcohol), then i'd go for a new maf.. make sure you have checked everything else, maf are expensive.
Old Nov 3, 2000 | 03:22 PM
fly89gta's Avatar
Car: 2018 Camaro SS
i know...i'm gonna try EVERYTHING else before getting a new MAF...that is my last resort
89 GTA
Tony
Old Nov 4, 2000 | 11:40 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I had the same problem too. I had already changed the MAF sensor (wish I hadn't), and still kept getting the code. So I went to the relays, they may operate if you check them by applying power to the coil but if they have any buid-up on the contacts then the voltage going across will decrease. And that's when you get that low voltage code. Try either taking the relays apart and cleaning the contacts or replacing them.
It worked for me, try it.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
