A.I.R. delete
Old Jun 28, 2007 | 07:36 PM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
A.I.R. delete
I was looking to maybe delete the air pump system from my car. It's and 89 formula 350 and looking to clean things up under the hood and also gain a few extra ponies. Does anyone have any suggestions on this and has anyone done this and will I need to re-burn my chip or anything? Thanks for any help at all.
Old Jun 28, 2007 | 09:13 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: A.I.R. delete
Wont need to re burn a chip or anything. Pull the pump out, dont even need a delete pulley. See how the belt fits, might have to go smaller. Put pipe plugs in the exhaust manifolds where the lines used to go in and close off the line to the catalytic converter.
Old Jun 28, 2007 | 09:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: A.I.R. delete
Its a federal offense to remove your street vehicle's emissions components, regardless of your state or local emissions regulations.
Old Jun 29, 2007 | 08:27 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: A.I.R. delete
I removed mine and used a delete pulley. I had a Moates adapter made by TPIParts to disable the AIR along with a few other things.
Old Jul 1, 2007 | 07:31 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: A.I.R. delete
Agreed with Matt. We did my buddies 89 GTA. Just search for a new belt size. I think he found it here on the site.
Old Jul 1, 2007 | 08:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: A.I.R. delete
wouldnt know what the belt size would be by chance?
and is the smog/air pump stuff heavy at all? my a/c was 23 lbs empty and that includes all lines and the compressor but not the condenser
Old Jul 2, 2007 | 06:19 PM
MattODoom's Avatar
Car: '88 G T/A
Re: A.I.R. delete
So... are you going to turn him in or something?
Old Aug 4, 2007 | 09:56 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Re: A.I.R. delete
968K-6
Thats is what I run on mine. No delete pulley.
Old Aug 4, 2007 | 09:58 PM
heavrolet9894's Avatar
Re: A.I.R. delete
If I were to do this woud I need to disable my egr valve in anyway?
Old Aug 4, 2007 | 10:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: A.I.R. delete
i dont believe the EGR and AIR are connected in anyway. to disable EGR tho you just gotta go into the chip and disable a few things..it was easy and my car runs just as good if not better now (Gas mileage wise)
Old Aug 5, 2007 | 10:39 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: A.I.R. delete
LOL, Kevin had to say that (being a moderator), as this website can get in trouble for encouraging the violation of federal legislation. Although, there are in fact ways around such legislation (being that the OP's car is an '89), but your limited to a certain amount of mileage on an annual basis though (keep the possible speedometer tampering responses to a minimum)....
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
