Stock cc on 88 TPI heads
Old Nov 5, 2000 | 01:22 AM
Transformer's Avatar
Does anyone here know what the stock cc`s on the L98 heads are??
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Old Nov 5, 2000 | 07:41 AM
Aaron's 87's Avatar
L98 AL heads are 58cc on the Vette.
Old Nov 5, 2000 | 01:23 PM
Mark 89Formula's Avatar
The iron heads have 64 cc chambers. In the past board members have measured and validated that number. Actual measurements vary 1-2 cc (usually on the high side) due to production tolerances
Old Nov 6, 2000 | 02:18 PM
Thanks for the help guys.
Old Nov 6, 2000 | 02:26 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, I have contacted GM and they have confirmed that Iron Head L98s had 64 cc combustion chambers. So its official.
Old Nov 7, 2000 | 11:56 PM
98_1LE's Avatar
What is the dish on the piston and the stock compression ratio?
87 Formula 350 14.61@94.07
98 Z28 1LE 13.15@107.59
Old Nov 8, 2000 | 04:40 AM
Night Hawk's Avatar
Stock compression ratio on a L98 is 9.3 : 1
Old Nov 8, 2000 | 09:32 AM
blak92!'s Avatar
incorrect on the compression ratio's for 91-92. The correct compression ratio for 91-92 B2L (L98) is 9.75:1.
GM used less of a dish and lighter weight cast pistons for 91-92.
Old Nov 8, 2000 | 06:09 PM
98_1LE's Avatar
What kind of pistons do the '87 L98's have?
Old Nov 8, 2000 | 06:48 PM
Car: Death Mobile
Engine: 666 c.i.
Blak92 is correct about the 9.75:1 compression ratio on B2L L98s for 91-92. I have had this confirmed by GM (and my 1991 GM Shop Manual) too. I believe 90s were 9.5:1 also, though I have not confirmed this with GM and I don't have a 1990 GM Shop Manual.
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
