check out all of my new mods
Old Nov 7, 2000 | 02:29 PM
saul 87vette's Avatar
project superstock is finally done. i will be driving it in a day or 2. for those who werent following it with me, i wanted to make my 87 vette run about like a stock ls1 or around there while still maintaining good drivability and stock look. it has taken me many many hours of work to finish this project. i used every source of info and every formula i could to determine how the parts would work together and with the car.
i also upgraded the looks of my car with 18" y2k vette wheels. i have my nitrous system completely hidden and my engine has stock everything which can be seen. see sig
Old Nov 7, 2000 | 02:57 PM
'89Formula305TPI's Avatar
sig?
Old Nov 7, 2000 | 07:49 PM
JeffP's Avatar
Yeah, what exactly did you do?
Sounds nice by the way
Old Nov 7, 2000 | 10:54 PM
oops, no sig on here.
ill just tell you all what it has.
It is a late model 383 with a 212-218 duration@50 and .480 lift-.490 rollercam.
i used trickflow twisted wedge heads and a ported and polished stock intake base. i used polished and mildly ported intake runners with a stock plenum along with a stock throttle body and an airfoil. i used a new waterpump,cap and rotor, plug wires, and all the little things. this car has all of the free mods and has a 160 degree thermostat with the fan wired to be on at all times. i have my dual 3" exhaust custom all the way back with dynomax strait throughs and an h pipe, i used stock headers.
i still need my chip, of which i am burning my own. and like i alluded to i have 18" y2k vette wheels all the way around with 265-35-18 yokahama nexus all the way around. the nexus tires are nearly slicks. what do you all think?? i love the way that this car looks stock to even a trained eye, even the 150 hp nitrous kit is stealthy.
Old Nov 8, 2000 | 03:50 AM
evilho7810's Avatar
Wait a second! you're telling me that with a 383 and 150 shot your only running around what the new vette's run? Man you should be running 11's!
Old Nov 8, 2000 | 08:19 AM
Aaron's 87's Avatar
I'm building and 87 Vette also. My stock exhaust manifold ports were about 1.2" across, while the head exhaust ports were about 1.5" across. Switching to headers should gain some serious hp in a modified motor.
Old Nov 8, 2000 | 09:57 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
nice setup but isn't that stock intake choking that 383? i know u ported and polished but it still the stock intake....i would invest in some after market runners and an aftermarket base....that should really help that engine breath...what is the stall speed on your torque convertor?
89 GTA
Rice....it's whats for dinner
The left lane is for passing...if you aren't passing get the f*ck out of my way!
Proud memeber of the South Jersey Fbody Crew(all 2 of us!)
http://www.hometown.aol.com/clarkemustgonow
Tony
Old Nov 8, 2000 | 01:18 PM
i should be running about like the new vettes without the 150 shot, it is insurance. i am getting a better intake later but part of my goal was to see what exactly i could do with this stock configuration. i am going to go with an aftermarket base and the asm tube runners and a ported plenum in a few months or sooner if im not happy with the new times.
my converter is the high stall from early vettes, i think it is 1800 or something but i have loads of lowend torque and my cam has 212 intake duration so i dont need a whole lot of stall speed. this car should handle like its on rails with 18s and 265 wide all the way around. im only looking for low 13s without the nitrous. low 12s with it maybe high 11s if really works out well but i doubt this fast
Old Nov 8, 2000 | 01:21 PM
oh and you are correct about those stock headers, i am going to have to get some good 1 5/8 headers, i am looking for stock look alikes but with 1 5/8 tubes.
Old Nov 8, 2000 | 03:56 PM
JeffP's Avatar
Sounds like a nice setup...Did you add a stroker crank to your original block?
You also run a 2.56 rear, right? It will certainly be something if you can break 11s with 2.56s!!
Old Nov 8, 2000 | 04:09 PM
i now am running 3.07s in the rear so that should help me out alot. i did not just add a crank i used a whole new longblock. i will have my old one for sale complete if anyone wants it. 11s is being very optimistic, even with the juice on! i can hope though
Old Nov 8, 2000 | 04:15 PM
JeffP's Avatar
Did you buy a stroker long block complete, already assembled? If so, where did you get it from, if you dont mind me asking...
Old Nov 8, 2000 | 09:56 PM
speed o motive. complete shortblock i added the heads and all acces. looks like a real pro job, i am yet to actually start it
69 Six Pack
Oct 5, 2015 07:51 PM
Wade787b
Sep 29, 2015 01:15 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
fbirdroller
Sep 2, 2015 10:27 PM
1LE91
Aug 31, 2015 08:13 PM
