performance tpi rebuild,
Old Jun 30, 2007 | 12:10 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
ok before i start please no one reply with just replace it with a 350, i have another race car with a 385Fast Burn, This is just a block I have laying around and I want to have some fun just to se what #'s I can pull out of it,
Stock 305 Block
Hypernuertic Pistons
Forged Rods
1.6 Rockers
Reground Crank
Stock Cast Iron Heads
Holley Stealth Ram Plenum and Intake Manifold,
Ford 24lb Injectors
Holley Fuel Rails
Heddman Headers
Holley 58mm Throttle Body
That is what I have for it now,,,, with that being said,
Does anyone have recomendations for a camshaft and lifters to go with this setup,... it is the only thing stopping me from completing the engine....
Preferably a cam that I can install and leave in once I install the vortec supercharger.... might not be for a few months, want to get it back in the car and running before the charger is added.
Old Jun 30, 2007 | 12:40 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: performance tpi rebuild,
a good afpr, like the grand national one, Kirban makes/or has one (i need one)
I would go in the 210-220's duration at 50 zone. I went with a cc 306 by comp (350), I would go 1 or 2 sizes smaller on a 305. Mine sounds mean, and idles great at 650-700 in gear. I am going turbo. anything on a 112 or 14 center helps alot with the overlap.
if you don't have the cubes, boost is just as good....
OHHHH PORT THOSE HEADS, do a search on those heads/ ported, will make alot more possible
Last edited by fun Pain; Jun 30, 2007 at 12:42 AM. Reason: OHHHH PORT THOSE HEADS, do a search on those heads/ ported, will make alot more possible
Old Jun 30, 2007 | 01:44 AM
kelham's Avatar
ok great, thanks for the head info,,,
what do you think about this cam, think it will get the job done...
CRN-104224 Crane Cam Summit Racing Part #
and as far as a afpr, something like the aeromotive ones,,, do i need 1 input 1 out put or what setup
Old Jun 30, 2007 | 08:15 AM
fun Pain's Avatar
Transmission: 4l80e
that would be fine (afpr), or the kirban one mounts the same as the Holley one does, no special fittings and a little cheaper way of going.
Cam wise, that one looks good to me... see what the other fast 305's are running cam wise.... I don't recommend useing one with anymore lift then this one or you will be really wasting money in stubs, getting the guides down.... a real waste in these heads...
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1989formula5.7l
Aug 15, 2015 11:35 AM
Sanjay
Aug 12, 2015 03:41 PM
