High idle while driving, seems like stuck throttle
Old Nov 9, 2000 | 07:37 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
When I drive the ECM idles the car at 1500-2000 untill I stop or tap slightly on the gas. Sort of like a stuck throttle. I do not have a binding throttle or linkage. I replaced the TPS because it was not giving smooth increase. No change.
I also found the TPS sensor was rubbing on my Accel 58mm throttle body. Filed it down, no change.
Hooked up my scanner and the IAC (stepper motor) is ay 47-50 steps during the high idle, according to the book it should be 25 steps. This I think is causing the high idle. I am not 100% sure though.
What drives the IAC and why or when?
I am not along with this perticular problem, read other peoples comments and you will see. www.thirdgen.org/messgboa...00129.html
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old May 14, 2005 | 12:37 PM
Vader's Avatar
Or a sticky IAC, or a vacuum leak (like a sticky EGR or EGR solenoid).. Or, a sticking throttle plate/shaft.
Old May 14, 2005 | 02:41 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
i had a high idle the other day and hooked up my scan tool, saw that the cts was reading 40 degrees f when it wasn't even that cold outside! Replaced the cts and everything is fine.
Old May 14, 2005 | 04:54 PM
Engine: 4.0L
Guys this post I made was 5 years ago.
To answer the question i had it was a sticky throttle plate, an extra return spring solved it for good.
Old May 14, 2005 | 05:20 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Better late than never.
Old May 15, 2005 | 01:31 AM
Vader's Avatar
I presumed you'd had it figured out by now, but just in case...
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
