Need AFPR Help
Old Nov 9, 2000 | 04:48 PM
the roc's Avatar
Need AFPR Help
I did a search and have found that others have had this problem. What is the deal? I pulled the top off the stock regulator (working fine - nearly new diaphram), left the diaphram in the "base", put on the Accel AFPR top,, and now my fuel pressure stays the same whether vacuum is hooked up or not. UGGGHHH. What could be the problem? I mean I've worked on cars enough and I followed the instructions,,, I mean come on this is not a hard mod to do!!! I took my time,, it should work right - - -UGGHHHH!!!!
Old Nov 9, 2000 | 09:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just out of curiosity, have you tried bumping up the pressure? Any change? Was the bolt bottomed or topped out?
Old Nov 9, 2000 | 09:16 PM
theformula's Avatar
Replace the internal pieces of your STOCk regulator (spring and orange gasket type thing). That has solved the problem on mine and many others. I gurantee that is what is wrong.
DO NOT GET IT FROM THE DEALER. THey will charge you $95. Go to parts america or advanced auto. I got mine for $29. Its listed under MPFI not TPI.
Good luck.
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
Old Nov 10, 2000 | 02:00 AM
BadSS's Avatar
Well Rock,,, I think I know what the problem is. A month or so ago,, I was having the same problem (probably me you mentioned). The AFPR kept the same psi whether the vacuum was hooked up or not. I bought the car with a Crane AFPR the guy said would not change pressure, I replaced it with an Accel unit and figured something was wrong with the base portion of the regulator since 2 AFPR were doing the same thing. I bought a complete regulator assembly from GM, installed it,, and presto - the pressure dropped to 34psi with vacuum from about 41 with out. Tonight I figured I'd put the Accel top on so I could adjust the fuel pressure. Well,, still no drop when vacuum line is applied.
Long story short - Accel had put a plastic "plug" inside the vacuum nipple. The mother ruckers cost me over $100!! Unscrew the nipple and check to see if your's is "plugged" as well. I pushed it out with a small allen wrench,, and I'm FINALLY good to go!!!!!!!!!!!!!!!
[This message has been edited by BadSS (edited November 10, 2000).]
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
