Car will not stay idel AGAIN, should I replace my IAC?
Old Nov 10, 2000 | 11:10 AM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Ok, goes like this. I did the paper clip adjustment for the IAC and my car started back up and ran fine. 2 days later (today) I go out in the morning to start her up, 5am snowing and very very cold. Again, same symptoms, and the paper clip adjustment in the A and B terminal does not work. Could my IAC just be totaly shot? Why would the cold do this? What could this be? In warm weather, she never has problems like this.
Thanks!
25th Anniversary Z28
Old Nov 10, 2000 | 01:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Maybe you should clean out the carbon in the IAC motor's passageway? Gumout makes a "throttle body and intake cleaner for fuel injected engines", sold by the carb cleaner. (You shouldn't use carb cleaner in a fuel injected motor). Remove the IAC, and spray the cleaner into the hole.. it should dribble carbon out through the throttle body.
If you want to clean the IAC's pintle with the spray, do so with the pintle pointing down, and the connector/motor end of the IAC up. This is because any cleaner that gets inside the motor will ruin it! If you hold the pintle downward and spray it, gravity pulls the cleaner down and keeps your motor safe.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 10, 2000 | 04:38 PM
GOFASTER's Avatar
Engine: 388 ci
So, what you are saying is remove the IAC (the small black thing with three inlets and a lever thing on the back) and spray the whole thing real good with "gunk" cleaner and install it and she should work?
I will try it and let you know. If not, then I should just replace it, right?
Now the IAC is the small black thing attached to the passanger side of the TB, with three inlets and a lever on the back?
Just making sure.
Old Nov 10, 2000 | 04:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Just making sure.
No, that is the TPS (throttle position sensor). The IAC (idle air control) is on the bottom of the throttle body with 4 wires going to it.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
[This message has been edited by John Millican (edited November 10, 2000).]
Old Nov 10, 2000 | 08:22 PM
GOFASTER's Avatar
Engine: 388 ci
Ooops! Thanks, now I know. But, it is the TPS that is fu@king up on me. I removed it and cleaned it up and now she runs again??? I can't figure it out, one min she is running and the next she is not.
Anyway, thanks!
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
