max fuel pressure?
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
max fuel pressure?
Ok I have an adjustable fuel pressure regulator and it is set to 50 psi at idle. Now since it has a vacuum port the pressure changes with the rpm and intake vacuum. At wide open throttle how much more pressure will I see above 50 psi?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: max fuel pressure?
Regulators are there to only maintain a constant pressure differential.
More or less if u drive around with a fuel pressure guage on the car u will be able to observe 5-7 psi swings depending on throttle openings.
Only way to truly do it would be able to get vacuum and fuel pressure at the same time and record it.
later
Jeremy
later
Jeremy
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
