code 36 - the one that wont go away!
Old Jul 5, 2007 | 07:44 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Ive had this error code for a good 7 months, i replaced the maf burnoff relay but that hasnt done anything.
If i disconnect the battery for a few seconds then start up, the light stays off on the dash, but if i switch off and restart it comes back on.
The car itself is running great, but the SES light is always on. could it be the actual MAF sensor or even worse, a problem with my ECU ?
Old Jul 5, 2007 | 08:32 AM
elcam84's Avatar
Re: code 36 - the one that wont go away!
Did you replace the power relay? Burn off power feeds from the burnoff relay through the normally closed contacts of the Power relay and then to the MAF.
This keeps the MAF from going into burn off while the engine is running.
Old Jul 6, 2007 | 08:33 AM
gta_knight's Avatar
Car: 1987 GTA
nope i only replaced the burnoff relay, thanks for that, ive got a full new engine harness to go in at some point but i think i will take the relay from it and try that out, thanks.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
