Base timing, Should it change when your rev up the engine?
Old Nov 17, 2000 | 12:38 PM
87Z-ya's Avatar
I was setting my base timing and decided to rev up the engine while Was setting it and the base timing changed. Yes the esc was unhooked. I run 8deg base and when I revved it up to about 2000 the timing jumped to about 15. Is this common? Or is my distributer worn out. I know they are not suppossed to have any kind of mechanical advance. Has anyone else tried this?
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Nov 17, 2000 | 01:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They have a small mechanical advance in 'em, it's normal.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 17, 2000 | 06:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its not mechanical advance, its just programmed into the module. Its like a "failsafe". If for some reason the ECM can no longer control timing, the module will resort to base timing, BUT when RPMs exceed a certain amount (it may be 2000) it will advance some so the car is still somewhat driveable.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
