code 34 maf
Old Jul 9, 2007 | 10:46 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
code 34 maf
i am getting lots of black smoke at idle flooding its a*s off really.could a bad maf cause it to do this?
Old Jul 10, 2007 | 08:07 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: code 34 maf
unplug the MAF. Does it run better? If so, MAF is probably the culprit, but you should also test the burnoff and power relays for the maf first.
Old Jul 10, 2007 | 04:53 PM
alpine247's Avatar
Car: 1988 IROC-Z
Re: code 34 maf
nah dont help it,but when i replug it back it gets better then about 5min it starts doing it again.and im getting the code 34 so probably what it is.just wanna make sure before i spend bout 200buck for a recond.
u think it would be the relay?but if it was wouldnt the computer give me a 36 i think instead a 34?
Old Jul 10, 2007 | 08:26 PM
Re: code 34 maf
depends on what relay, if either is malfunctioning. Check the terminals and wires at the connectors for the relays. The relays are the 3 up on the firewall. The other one is the fuel pump relay. You could even through the 20 bucks it would cost to just simply try replacing them anyway. Better then a 200 dollar guess, or spending a daig fee at a shop to figure it out. I feel your pain, I'm about to buy a MAF for my 86, I am certain my MAF is bad though, cause I hooked up the scanner to it at my shop, and it reads INSANE G/sec at idle. It reads 1700 with or without it unplugged, and If I understood my diag flow chart correctly, the MAF can go bad, and the ECM will just use default values set in the prom. Sometimes I get a light, other times I don't. I guess it depends on when the ecm feels like tripping the light it will, lol. I got a AC delco reman coming at me, at a special price. Shop price.
Old Jul 10, 2007 | 09:29 PM
alpine247's Avatar
Car: 1988 IROC-Z
Re: code 34 maf
well i unplug the wire going to the maf to see if its getting power it does so i guess the maf isnt working at all.and i do get a light, stay on all the time,it read out 34 so it must be the problem.im going to try to find one at a junk yard (25 bucks) plus all parts comes with a 30 day warrenty from there.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
