Ported upper plenum
Old Jul 10, 2007 | 11:12 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ported upper plenum
When i do this, how much hp would I roughly gain. If I were to buy a 52mm tb would that be used to its full potential? and lastly would i gain anything even with the rest of the stock intake parts? They wont be soon im thinking of siamesing my lower intake while im changin some injectors
Old Jul 11, 2007 | 08:24 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: Ported upper plenum
youd gain some but would get max if the whole air intake was ported out. meaning from air box to heads. do a search theres tons of info on it out there. also unless your looking for ungodly HP a stock TB is fine.
Old Jul 11, 2007 | 10:49 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Porting the plenum will give a few horsepower, but more importantly it will give improved throttle response.
Old Jul 12, 2007 | 12:13 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
PORT THE BASE. I added alot of power porting out the base.
Old Jul 12, 2007 | 07:26 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Didn’t seem to make it breath much better up top but oh my god, it completely changed response off idle. Nice and crisp now. And seems like I got 100-150more rpm. Auto tyranny seems to pull nice and even till factory shift points, softens up at 4600, used to soften at 4450-4500. Not bad for free, gaskets were new and soft so I didn’t even need to replace them.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
Reid Fleming
Oct 10, 2015 09:56 PM
