MSD 8.5mm Super Conductors - Question
I want to get the MSD 8.5mm Super Conductors for my '89 Formula 305 TPI. For those of you with these wires...did you get a custom length, or did you get the universal and cut them yourself? I don't want to mess with cutting them myself if I don't have to, but I haven't found a set specific to third gens. But I did see a set at Jeg's for "SB Chevy '88-up cars". Does this sound like the right set to get?
I also plan on getting the NGK plugs...any ideas on which ones or where to get them?
Thanks in advance!
1989 Formula WS6 M5
SLP cold air induction, K&N filter, TPIS modified MAF, TPIS 52mm TB w/ airfoil, Random Tech cats, SLP cat-back, TPIS AFPR, March underdrive pulley, Accel 300+ coil & 8.8mm wires, Bosch Platinum+4 plugs, Hypertech 160°F t-stat & fan switch, Hypertech Streetrunner chip, Centerforce dual-friction clutch, PST front suspension kit, PowerStop cross-drilled rotors, Porterfield Carbon Kevlar pads, Russell SS brake lines, Firehawk SZ50 EP P255/50ZR16.
G-Tech Pro measurements:
0-60 mph: 6.0 sec
212 RWHP
1/8 mile results: 9.74 sec @ 74.5 mph; 0-60 ft @ 2.35 sec; +0.46 reaction
2001 Trans Am WS6 A4
Stock
More info at website:
www.fbody.com/members/stevenmh
Thanks in advance!
1989 Formula WS6 M5
0-60 mph: 6.0 sec
212 RWHP
Stock
Car: Death Mobile
Engine: 666 c.i.
When I had my stock exhaust manifolds, I needed the mixed set specifically for SBC 3rd Gen F-bodies. When I installed my headers, I had to switch to the "all 90* boots" for SBC.
I've got some NGK's from O'Reily's and I'm really satisfied with them, They were cheap (around $1.19 a plug) and give good performance too, IMO. When I got my Accel SuperCoil recently I re-gapped my NGK's to 45 and REALLY noticed a power difference....
86 TPI 305 Iroc-Z
700R4 (rebuilt)
3.42 Posi
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams High Energy H268
86 TPI 305 Iroc-Z
700R4 (rebuilt)
3.42 Posi
Accel HEI SuperCoil
Flowmaster
K&N Filters
NGKs are excellent plugs. I recommend running one level colder than stock since you have an aftermarket ignition. Just to be safe. Look at your spark plugs. If its melted you need a colder plug. If its tan everythings ok. If its grey you need a hotter plug.
I just ordered the MSD wires. The custom ones will fit, Im installing SLP headers and I didnt buy the custom wires because Im not using a wireloom.
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
'92 Formula
305 TPI 5speed
1LE package
tartagliaz28
Aug 15, 2015 10:59 AM
