Purge canister
Old Jul 12, 2007 | 09:46 PM
heavrolet9894's Avatar
Purge canister
What is the main purpose of the purge canister? Do I really need it? I have a stock 350 TPI with smog delete and EGR removed.
Old Jul 13, 2007 | 05:33 PM
deadtrend1's Avatar
Re: Purge canister
you mean the charcoal canister? It allows the gas tank to vent its fumes and store those fumes until the engine is a part throttle cruise and burns the vapors off. Instead of just venting the tank to the air.
It wont hurt you to remove it, but it wont hurt to leave it in....
Old Jul 15, 2007 | 09:18 AM
Vader's Avatar
Re: Purge canister
The little round valve on top of the EVAP canister also provides a method to control fuel tank vapor pressure at 1 PSIG. If you remove the system and plug the lines, tank pressure will be controlled only by the cap, and can achieve a lot higher pressure than the tank should handle. If you allow the tank vapors to simply vent, you can lose 5-7% of the tank's liquid volume within a week to simple evaporation. Pour a cup of gasoline into a coffee can and set it outside. Check it in a week (or less) and see how much is left. That's fuel and money wasted, regardless of whether or not it pollutes the air. And since the system doesn't require any engine power to operate, it doesn't create a power penalty to keep it. If you need the space for something else, like turbo intercoolaer plumbing or a cold air intake, consider installing a later model EVAP canister under the car. That's where you'll find them on most newer vehicles.
Old Jul 15, 2007 | 09:22 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Purge canister
If the original canister started going bad, would it be possible to find black soot underneath?
Old Jul 15, 2007 | 11:00 PM
Re: Purge canister
What kind of newer vehicle should I try to get a newer canister off of or does it matter.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BWilcox
Sep 20, 2015 12:19 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
