Idling problems
Old Dec 3, 2000 | 05:18 PM
3504mula's Avatar
Car: 90 Formula
Idling problems
My car seems to want to go dead when I come to a complete stop, (stop light, etc.) and I was just wondering if there was something I could do about it. Also, about 75% of the time I go from park or reverse to drive it will go dead unless I give it some gas (but I hate to do that b/c it doesn't seem to feel good on my transmission. Do you think a fuel filter will help? I bought one today and I was going to put it on while I was changing my oil since it was already on the ramps, but I couldn't find the old one. Is it in the rear near the tank? Any help would be much appreciated.
350 TPI, K&N filter, Moroso cam, Airfoil, Accel fuel pressure regulator and gauge, Hooker headers, Flowmaster 3" catback ...more to come.
Old Dec 3, 2000 | 05:51 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
try setting the TPS and the IAC as per the tech articles on this site.
you also could have alot of carbon crud either in your IAC pintle or in the egr passageways that could be causing the low idle.
first reset those two sensors. then if that doesnt work get some good throttle body cleaner (for fuel injected motors only) and spray right into your throttle body. unless there is some serious crud- this should do it.
BTW which headers do you have , the shortys or long tubes.?
james
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
no MAF screens, no cat, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
homemade ramair.
[This message has been edited by 88305tpiT/A (edited December 03, 2000).]
Old Dec 3, 2000 | 08:18 PM
3504mula's Avatar
Car: 90 Formula
They are long tube competition headers
Old Dec 3, 2000 | 09:34 PM
BP89IROC's Avatar
The fuel filter is on the driver side in front of the tank, Just look for the lines from the gas tank and you'll see the filter.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
