Which _BIG_ K&N for GTA?? W/in
Old Nov 27, 2000 | 10:54 AM
MINT1982CFI's Avatar
Hey all,
I've got an 88 GTA, and I've seen people with the same car that took out the ENTIRE black airbox, and stuck a high K&N Air Filter there.
Anyone know the part number?
Old Nov 27, 2000 | 12:23 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I don't have the part number, but it won't work very well on your car anyway. If you mount the air filter right on your TB like you are talking about you just eliminated your MAF sensor, and these cars don't run very well (if at all) without one.
Those filters are mainly made for the 90-92 speed density cars.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
Old Nov 27, 2000 | 02:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Leave the tubing, but stick a big K&N cone filter on the end of it, like the 4th gen kits have.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 27, 2000 | 06:43 PM
dudelovett's Avatar
How would one of the conical systems work on my 91?
Ive heard that Ram-Air is better.
1991 Firebird Formula, 305, TPI, Auto...stock till I get some money!!!
Former owner of an 88 2.8 Firebird....RIP
Old Nov 28, 2000 | 09:58 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
you could stick the cone onto the end of your stock airpipe where it connects to the airbox (if it has the right kind of joint). If the end is not round, then you can take the stock airbox and buy a K&N to fit...then you could cut out parts of the stock airbox to allow more flow. don't get one of those that sticks on the end of the TB, you'll only be sucking hot air.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Old Nov 28, 2000 | 10:14 PM
89GTA5spd's Avatar
I put one of those conical k&n's in place of my airbox. I forget the part number though.. just get the one that has a 3.5" opening and stick it to the end of your intake pipe. I removed the vapor canister and airbox mounting plate to give enough room for the filter. I couldn't tell you if it is any better than the stock box, but it's only 30 bucks or so, and it looks a lot better than the box. One day if you get really ambitious you could fabricate a aluminum pipe or something and it would look better than the stock plastic intake tubing..
Old Dec 5, 2000 | 09:36 PM
formuladave's Avatar
IMHO I'd recommend the SLP Cold Air Induction setup for your car if you have the cash. Mine cost about $200 a few years ago. I run a K&N inside the box (you only need one filter despite Summit saying you need two). Sucks cold air from underneath the car and you get the benefit of the K&N breathing.
Dave
87 Formula 350/auto
Flowmaster Cat Back
SLP Performance Y-Pipe
52 mm BBK Throttle Body w/airfoil
Ported Plenum
Accel 300+ Ignition
Adj. FPR (44 psi)
Hypertech PROM
Hotchkiss STB
Global West SFCs
Global West Steering Brace
Jamex Springs
Old Dec 5, 2000 | 10:40 PM
Thanks to everyone for their input -
I ended up ordering a Conical K&N Generic filter from Jegs, with the 3 1/2" diameter opening for $35 incl shipping. It fit RIGHT in place of the black airbox, which I removed by using a 13mm socket on the one bolt that was holding it down, and viola! I clamped it on to the tubing from the TB, after the MAF, and it works perfectly
DEFINETLY Noticed an difference after installing, and I love it! I recommend it to anyone!
BTW, the car was an 89gta, TPI (obviously)
Lata All
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bigjay89gta
Oct 15, 2015 08:04 AM
2012sergen11
Oct 13, 2015 07:38 PM
meeklay812
Oct 1, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
