Air temperature sensor relocation.
Old Dec 3, 2000 | 09:18 PM
BP89IROC's Avatar
Are there any drawbacks to relocating the manifold air temperature sensor to a place in the air cleaner assembly? I hear that it gives the computer data that is closer to what it is actually supposed to be getting.
1989 Iroc-Z TPI 350 auto 4-spd Removed MAF screens K & N filters, stock other than that.
Old Dec 4, 2000 | 02:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It makes your car run richer, as the computer seeing colder temps makes it give more fuel. I had to put mine back to stock as I was running too rich. But if you're lean, its a great way to get more fuel.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 7, 2000 | 06:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
from what I've read in the code the TPI 3rd gens only use the IAT for a perimeter of when to apply the EGR. Mounting it in a cooler place just turns the EGR on less.
Old Dec 7, 2000 | 08:53 PM
rwelch's Avatar
IAT (intake air temp?)-same as MAT? If one disables the EGR is the MAT necessary?
Old Dec 8, 2000 | 01:54 AM
Omar's Avatar
Like Kevin said, the MAT is for the ECM to see what temps are coming into the intake. It does delay the EGR control if it is too cold, but the MAT is not solely for EGR control.
1989 IROC-Z 5.7L
Old Dec 8, 2000 | 07:55 AM
Lounge Lizard 6's Avatar
When I did the MAT relocation I felt an immediate improvement to part throttle driving in low-speed, hot day driving. It made rush hour much nicer.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Dec 8, 2000 | 10:01 AM
90 Z28SS's Avatar
Hmmm...I'll have to try putting mine back . I've had a rich condition for quite some time and still haven't been able to figure it out , if this is the problem ....Kevin , I love you man
Derek 90 IROC 5.7
Mods: All the usual bolt ons , 2500 stall , 373's , SS hood , lotta reduced weight.
Best Et: 13.16@101
18" wheels , heads , cam and intake are on the way.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
92purpz28
Aug 11, 2015 02:30 PM
