Mass air to speed density
Old Dec 9, 2000 | 09:25 PM
dude12387's Avatar
is it possible????
Old Dec 9, 2000 | 10:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
With a new computer, like a 1227730. Oh yeah, and if you don't already have PassKey, you will need a custom PROM, or retrofit it in like I did. All S/D thirdgen TPIs had PassKey.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited December 09, 2000).]
Old Dec 10, 2000 | 01:36 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Do you have to change your wireing harness and if so how hard is it?
89 GTA 350 5-speed
(Jet hot coated) SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
G-Tech times
0-60 5.3s
E.T. 13.91@104.8MPH (2300ft)
Old Dec 10, 2000 | 07:31 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You wouldn't have to change the wiring harness, but you would have to alter it greatly. The MAF wiring harness won't fit into a S/D computer, therefore you would need the connectors for the computer and re-wire the connectors. Then just remove the MAF sensor wires and run some for the MAP sensor (or just use the MAF wires if you don't care about color correctness). A wiring diagram should walk you through it fairly well.
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
chazman
Aug 28, 2018 03:25 PM
Thornburg
Aug 27, 2015 08:28 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
