Siameseing and polishing SLP runners.. TIPS NEEDED
Old Jul 17, 2007 | 09:48 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello
i bought a set of slps for my car. I used a carbide cutting bit to siamese them all of the way through, then i started using flapper wheels to smooth out the inside. However i cant reach the middle with these flapper wheels. i think i need to find some kind of flexi shaft for my die grinder. I am also polishing these runners, but i am having a hell of a time, i polished my plenum already, that was easy, is there any tricks to sanding and then polishing the slps? thanks
Lee
Old Jul 19, 2007 | 03:49 PM
alabama_lowlife's Avatar
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
Re: Siameseing and polishing SLP runners.. TIPS NEEDED
to get further inside, i'd try using this flex shaft grinder from harbor freight. i have one and i love the thing. i've never tried to get inside the runners with it but, i think it might be what you're looking for. http://www.harborfreight.com/cpi/cta...emnumber=40432
as far as polishing goes, check out this buffing how-to by caswell plating. http://www.caswellplating.com/buffs/buffman.htm they also have some very good buffing products. they also have a metal polishing forum which you can browse and answer alot of questions. http://forum.caswellplating.com/forumdisplay.php?f=7
i also did a how-to on polishing a nissan valve cover for a nissan forum that i go to. http://www.nissancustoms.com/viewtopic.php?t=2431 here's some of my work http://www.undefinedcustoms.com/kelyn/polishing.html
i'd start with grinding any seams or ridges with a small sanding drum. then i'd go with a 8" spiral sewn buffing wheel on a bench grinder with greaseless compound. you apply greaseless compound to the buffing wheel and allow to dry and it hardens to the point that it will throw sparks off of steel. it works well on cast aluminum to smooth the texture without fear of gouging the metal. you would likely have to use some smaller wheels on the flexshaft to get in the tight areas with greaseless. then ah hell, it's all in the how-to lol
if you want to, send them my way, i'll polish them up.
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
