Is it possible..
Old Dec 11, 2000 | 06:31 PM
APCAMARO's Avatar
Is it possible..
to build a 383 out of my old 305 block? i have been told that they are the same block but can a 305 be worked into a 383?
thanks
Red 87'Z-28 350 tpi,MSD ignition 6al,gutted maf and airbox,
700r4 w/b&m shift kit and cor. servo
Old Dec 11, 2000 | 06:42 PM
IrocStan's Avatar
Nope,
the 350 and the 305 share the same crank, but the bore is much smaller on the 305. There is not enough material in the block to bore much more than .040(?) so I heard. I seen Super Chevy magazine put a stroker kit in one and got it to be about 335 or something around that size.
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Goal: 12.999
Old Dec 11, 2000 | 07:03 PM
chevyboy07 91's Avatar
As a side note, the 305 and 350 cranks are balanced different also, i believe.
Old Dec 11, 2000 | 07:57 PM
APCAMARO's Avatar
thanks, so instead of trying to use my old 305 block im just going to have to find a another 350 and bore and stroke it ?
Old Dec 11, 2000 | 09:32 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
the 305 and 350 are differnet blocks actually. You have to have a 350 block to start with before making a 383
'89 Formula 383 TPI
hectre13
Firebirds Wanted
Apr 19, 2015 11:10 PM
hectre13
18
Feb 9, 2015 08:28 PM
codyscamaroz28
Firebirds Wanted
Apr 12, 2014 11:00 PM
86 toy
Oct 23, 2013 09:47 PM
XxadgexX
