How to tell a 350
Old Dec 11, 2000 | 01:02 PM
Jason 85 IrocZ's Avatar
How to tell a 350
Hello
How do I tell if a engine is a 350? when out of the car(so no vin to go by). Where on the block are the numbers and what will the 350 numbers be?
Jamieson
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1991 RS
1999 Oklahoma Gathering
2000 SWMG
Old Dec 11, 2000 | 02:40 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
The block should have 5.7 stamped on the side towards the back. I forget if it's on the driver or passenger side, but it's fairly big so you should see it. Also you can measure the bore of the cylinders. A 350 has a 4 inch bore diameter.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Dec 11, 2000 | 06:47 PM
IrocStan's Avatar
Any small block later than 87 will have the size in Liters stamped in the back of the block, but anything earlier will have a number that you will have to look up. It is the left rear top of the block, right behind the cylinder head.
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Goal: 12.999
Old Dec 11, 2000 | 10:54 PM
Ed Z28 350's Avatar
I remember 5.0 was stamped on my 86 305 engine, so it probably goes further back than 87, but I don't know what year the stamping started.
Edwin
1986 IROC, 1992 Body Kit, 1989 5.7 IROC Engine, Crane Cam, 3" CVX Exhaust, ADS Superchip, 24# FoMoCo Injectors, Gutted Cat, AFPR (45 psi), Airfoil, 3.42 Gears, MAF Screens removed, Gutted Airbox, K&N Filters
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
