how much power can I make with TPI
Old Dec 15, 2000 | 02:06 PM
85350TX's Avatar
I am thinking about selling my 78 T/A and buying a 91-92 firebird and building up a 383 stroker and later adding a supercharger and I wanted it to be TPI. if I get the edelbrock base along with SLP runners can I get one to flow to 5300-5500 RPM I really donot want to turn this sucker past 5500 so I can use stock rods with confidence I want to make it a torque beast. or is the only way she is gonna make power thru a mini or superam? also with a supercharger to I need to turn serious RPM to take advantage of it?
Old Dec 15, 2000 | 04:25 PM
theformula's Avatar
When Vortech bolted a S trim unit on to a stock L98 it made 350hp. I'd go with ATI for our cars though.
With edelbrock base+runners, AFR 195 heads, a cam that stays around 212/220 .480.485 and 114 or higher, 1 3/4 headers, free flow catback, ATI w/aftercooler...
You will see the power I think you're looking for.
But big gains can be had by switching to a Superram or Miniram when running a blower. The stock block can take up to 6500rpms by the way.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 15, 2000 | 05:07 PM
85350TX's Avatar
Thanks theformula I am wanting the exact bodystyle you have. Have you made some decent power with your 305 I was going to do some mods to the car before I drop the 350 or 383 in and wanted to know what I can expect. I am wanting a good mid to low 12 second car with this combo that handles pretty well and idles in traffic. My daily driver is a 2001 Z/28 it should pull mid to low 13's stock so I am wanting some thing that is a good second or so faster than my camaro.
Old Dec 15, 2000 | 05:08 PM
85350TX's Avatar
by the way how much do the superam and the miniram cost? and I am looking for about 400 RWHP
Old Dec 15, 2000 | 08:32 PM
leirch's Avatar
www.lingenfelter.com
for the superram prices.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Sanjay
Aug 12, 2015 03:41 PM
