SuperRam + Manual Tranny?
Guys,
I have a Superram and a stock T-5, the cruise control looks as if it has been removed. Does anybody have a picture of a Superram setup with a Stick? Mine works but it looks as if a return string has been "rigged" up to pull the throlle closed.
It just looks totally out of place. I've seen some superram/auto pictures and they look different.
Here is a picture of how it looks now.
www.geocities.com/leeson.rm/augeng3.jpg
Any pictures of how a Superram/stick should look would really help!
Thanks,
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Thanks,
Brendan
Car: An Ol Buick
Engine: Vsick
Originally posted by leirch:
Guys,
Thanks,
Brendan
Guys,
Thanks,
Brendan
I'd bet there is a cable problem.
Or the IAC needs cleaned and reset.
Thanks grumpy. I am going to take the spring off totally and see how far things are off or should i say sticking open.. Then probly reroute the cable under the superram where it is sposed to be.
I'm still looking for some superram pictures to look at for ideas. Ones with autos would work also but would prefer stick cars...
Thanks,
Brendan
Thanks,
Brendan
Don't know yet, still need to do some more tuning and take it to the track.
Pac J
May 17, 2020 10:44 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
