Does anybody know anything about Code 32
Old Dec 17, 2000 | 05:23 PM
IrocZ335's Avatar
I have a 1986 305 IrocZ, I have removed all smog equipment. After I removed the smog equipment a code 32 started popping up when I travel a distance of at least 15 miles at a constant speed of at least 50 mph. The performance of the car doesn't change but driving for a long distance with the "Check Engine Soon" light on is kinda annoying, especially at night. Anyone that can help please reply.
Old Dec 17, 2000 | 07:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
EGR
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 18, 2000 | 09:11 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Code 32 has to be one of the folowing:
Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch
OR
Fault in electronic vacuum regulator valve
Hope this is of some help
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
