400 TPI?
Old Nov 28, 2000 | 09:51 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
400 TPI?
I plan on putting a 400 under my tpi right now I am using 24# inj. and a 52mm throttle body will it feed the required fuel?
Old Nov 28, 2000 | 10:09 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
As long as you don't have any kind of power adder and you do have a custom chip you'll probably be alright. What are your other mods to it?
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Old Nov 29, 2000 | 06:06 PM
Engine: ls1, LB9
I will be using a bigger cam in the 400. no chip though the 350 runs like a raped ape with the factory one.
Old Nov 30, 2000 | 12:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Just make sure you wont go lean......
I'm planning of stroke my engine to a 383 and I will try to have same injectors and prom.....
Old Dec 19, 2000 | 05:31 PM
Ragtop Man's Avatar
One of the recent books had a formula for calculating the desired injector size... think it mighta been GMHTP.
Might want to throw a post to Johnny Hunkins to see if he still has his ears on the board.
BOB
Old Dec 20, 2000 | 01:06 AM
Z28Maniac's Avatar
There is an article on selecting injector size at http://www.iroc-z.org .
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
