What belt to use?
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
What belt to use?
I got my BBK underdrive pulley set and it says to use a 92.3" belt. Im haveing a hard time finding one, the closest I"ve found was a 92.2", and a 92.6". I was thinking that the 92.2" may be a little small, think I could get away with the 92.6" belt?
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: What belt to use?
Probably. Your best bet would be to run a string around all your pulleys and measure exactly what you need. Make sure you don't forget that the tensioner needs to be in the right spot.
MrPackstin
Oct 25, 2017 08:09 PM
