to 11 second 350TPI owners
Old Dec 13, 2000 | 05:15 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
What does it take to achieve this? I'm going to buy a 350 soon and want these kind of numbers out of it. Any help is appreciated.
Old Dec 13, 2000 | 07:46 PM
mtx28's Avatar
boy you is crazyy! you'd be doin some DANG serious work to a tpi to get remotely there.. i dunno if it could even be done, why dont you go w/another type of EFI that would be able to feed the amount of air you'd need much easier? but... there's something cool about being the first one to try something.. good luck
Old Dec 13, 2000 | 08:48 PM
BP89IROC's Avatar
I would have to say that to get your car to run those times you would need to put your car on a diet. Get some really good heads, aftermarket runners, intake, and ported plenum, and one hell of a cam. And if that doesn't work your gonna need nitrous or a sc.
Old Dec 13, 2000 | 09:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ive seen it done with stock heads and cam in GM Hi-Tech mag . he had a ATI Blower and a 150 shot NOS
Old Dec 13, 2000 | 09:37 PM
mtx28's Avatar
yea.. what kind of boost was he shoving in htere? enormous amount for sure. that irks me. to say 'yea i got an 11 sec car w/stock heads..' but yea, he's got what? 15psi or thereabouts AND 150 shot of nitrous ? he better be goin that fast
Old Dec 14, 2000 | 02:49 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If u want a 350 TPI to runs 11's on all engine, u will have to mod a lot of stuff in the engine, but there are guys that have them.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
Old Dec 14, 2000 | 06:27 AM
F22Raptor's Avatar
Come on people, this can be done very easily. The only real restriction you have when modifying a TPI is money. If money is no concern, here is a recipe that should get you pretty close to that goal.
- TPIS Miniram with 58mm throttle body
- Aftermarket aluminum heads (these will have to flow a lot, 200cc intake runners or maybe even bigger, 2.02-1.60 valves or bigger; at least 11:1 compression ration)
- Big cam, something like 245* duration, 550” lift and a 110* lobe separation angle or bigger
- Full exhaust, this means at least 1 ¾ headers (1 7/8 would most likely be better, long tube even better) and a 3.5 or 4” catback (no cat of course; and yes, there are 4” catbacks) or a 3-3.5” cutout right before the catalytic converter
- 3000-3500 RPM Stall Converter (10” for reduced weight)
- 4.10 rear gears
- Weight reduction throughout the car (rear seats, light weight wheels, and tires, etc)
- Chassis update (subframe connectors, Aftermarket torque arm, etc)
- Extensive PROM tuning. I would go with Speed Density so the MAF is not a restriction
I might be forgetting something, but this should be enough to put you in the 11s; if this fails (which I really doubt), then you have 2 more options: a 150 hp nitrous shot or a supercharger. Either WILL definitely put you in the low 11s.
**Note that the bottom end might have to be beefed up considerably**
If you ever decide to do something like this, please post results (yeah, like if you would hold back)
Rick
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
13.40@102.55 MPH
1.90 Sec ------- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Old Dec 14, 2000 | 06:50 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Like F22 said, the only restriction is the mighty buck. My signature gives the end result, but here are most specifics:
Best e/t's:
Naturally aspirated: 14.07
90-hp shot nitrous: 12.58
Supercharged (6 psig): 12.57
Supercharged (6 psig) & 50-hp shot: 12.04
I know my best naturally aspirated time could be significantly better, but my engine was designed (and mods selected) for a supercharger. I attained these times with a 305, so with a 350.......
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Dec 14, 2000 | 05:24 PM
mtx28's Avatar
oh, money? is that the only restriction? what a revelation
Old Dec 14, 2000 | 09:47 PM
black5.7GTA's Avatar
F22 is right on the money.plus bigger injectors,(24lb atleast),a higher pressure fuel pump,a full ignition system,a cold air,and some dragradials,or cheaterslicks and high 11's are very possible.
1990 Trans Am GTA
Bosch plat+4 plugs,SLP plug wires,Hypertech coil kit,Fastchip PROM,SLP 160 therm,T-body bypass,SLP crankpulley,Breathless AFPR,,ported plenum,SLP runners,SLP flowbooster,SLP cold air,K&N,SLP 3"catback,SLP torqueconverter,SLP shiftkit,Mobil 1
14.3@96 stock
13.5@102 w/mods
Old Dec 15, 2000 | 12:33 AM
F22Raptor's Avatar
mtx
you "is" the one on crack. He asked what it would take, so I told him.......by the way, what do you run??
Old Dec 15, 2000 | 10:59 PM
mirage2991's Avatar
Stock limited class ran 12.06, stock TPI...off cours with at 1.4 60'time...I saw it and saw the engine too...stock TPI...I couldn't belive it...but sure enough...
Guess everything is possible with good launch!
[This message has been edited by mirage2991 (edited December 15, 2000).]
Old Dec 16, 2000 | 05:35 PM
Formula9's Avatar
Reminds me of an article I read. I'll check the achives.....2/98 issue of "High Performance Pontiac" magazine. Featured a naturally aspirated TPI 350 running 11.70s. (w/original short-block)
'89 Formula 350 dual-cat,T-Top
K&N, TPIS airfoil, Hypertech AFPR, ADS injectors,March pulleys, Edelbrock TES headers, Flowmaster cat-back, B&M shift kit, Performance Resource chip, SSM SFCs
Best:
1/4 ET:13.670
MPH:100.97
1/8 ET:8.773
MPH:79.57
60':1.974
13300mi, 245/45-16 BFGoodgrich Comp T/A ZR
Old Dec 16, 2000 | 08:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<ducking>
How about a 89 turbo trans am drivetrain?.
Good fuel pump, injectors, clever chipping, good exhuast. What speed just dial up the wastegate a tune accordingly. (overly simplified for easy viewing)
Old Dec 19, 2000 | 05:42 PM
Rob Gordon's Avatar
My car runs 11.90 at 110 with a TPI(edlbrock base, accell runners, ported plenum, 58mm tb)
about 380hp and 400+ ft/lbs
Iroc 350 5 speed
Old Dec 19, 2000 | 10:18 PM
87Z-ya's Avatar
I once saw a 89 gta that ran 11.90's back home in maryland at mason dixon speedway. It had stock intake, stock tb, corvette heads and a custom ground cam. He used an accel dfi setup to dial everything in, and was on slicks. It had a vigilante converter also, w/ 1.5 60 fts. And only a trap speed of 112.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Old Dec 21, 2000 | 11:40 PM
evilho7810's Avatar
He said 350tpi owners, not mini or superram owners. BIG difference.
Old Dec 22, 2000 | 08:14 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
F22 is on the money. Not too difficult to get to 11's. You just need significant money because you have to replace everything but the bottom end of the engine. I should be there in the spring. I'm in the process of putting in a higher stall converter, upgrading the exhaust, and putting in a bigger cam.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Dec 22, 2000 | 08:16 AM
TRAXION's Avatar
87Z-Ya....
I race at Mason Dixon. Was that 89 GTA red? There's a red GTA around these parts that looks stock but he has a big shot of NOS on it and runs 11's.
Tim
Old Dec 24, 2000 | 06:44 PM
89IROCZ
Guest
Posts: n/a
Personally, I do not see why 11's with a 350 TPI is that hard. If you have the money, it can be done relativley easily. Good heads, good cam, porintg of plenum-etc, new runners, all free mods, good tuning, good chip, headers with, good catback with no cat, good rear gears to with the 700R4, good converter and servo, and slicks. Not all that unlikely in my opinion.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Dec 24, 2000 | 09:29 PM
87Z-ya's Avatar
No this was a grey one. And he was a friend of a friend. He wasnt running nitrous. This car just hooked, the chassis was setup perfect. Was about a year and a half ago since I last saw him.
Old Dec 28, 2000 | 09:23 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
4.1 posi, headers w/ 1 3/4" primaries to full 3" pipe (no cat), fully ported/polished/worked tb, plenum, runners, intake and aftermarket heads (afr comes to mind), adj. torque arm, ati procharger w/ BIG intercooler, slicks, higher stall torque converter w/ lockup switch, and maybe a 50hp shot of nitro - and don't forget to lube all the calipers. That's more or less what my car will have eventually except with 3.73 or 3.23 instead of 4.1.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
