2 questions, Distributor related
Old Dec 29, 2000 | 12:57 PM
Ron Mullins's Avatar
I am going to replace the cap and rotor on my car,
Dumb Question number 1.Is there a key to getting the rotor button off? I thought they just pulled off and on. I can't get mine off.
Dumb question number 2. IS auto zone a good enough place to get the module at or should I goto a dealer?
Thanks all.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, MSD6AL, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Dec 29, 2000 | 01:43 PM
theformula's Avatar
You have to use a lot of pressure to get it out. I used a vice grip on my rotor.
Autozone carries a lot of AC Delco stuff. Just make sure the module you'll be getting is AC delco. Parts America/Advanced Auto sells the Ac Delco one though.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
Old Dec 29, 2000 | 01:47 PM
Thanks, I just got it off. I used channel locks and broke it off, Carefully.....
91 Formula WS6
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
