Car keeps stalling!! Help!!!
Old Dec 28, 2000 | 10:07 PM
FormulaGod's Avatar
after i threw out my 305 TPI and put in the totally modded 355 TPI, my car keeps shuuting off until it gets warm. WTF?? Can it be the wrong O2 sensor? I have the A/C Delco w/one wire on it. It connects to the headers. Thanks guys..
"Ever notice how imports sound like weedwackers"
Old Dec 28, 2000 | 10:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Define "totaly modded 355"...did you change injectors, EPROM, adjust the FP accordingly?
Old Dec 28, 2000 | 10:50 PM
FormulaGod's Avatar
Ok,
It has TFS heads, afpr, crane gold roller rockers, edelbrock 52 mm tb, edel base, edel runners, ported plenum, all free mods, headers, 3" flowmaster exhaust, hollow cat, msd 6a, F*** motor sports 24lb injectors, k and n. crane cam, STOCK 305 chip, and fuel pressure is about 42psi. I havent played w/ the TPS yet either. Its making a loud sucking sound, i gotta mess with it. 5-speed too. Thanks for the help!!
P.S. Procharger in the Spring..Wahoo!!
[This message has been edited by FormulaGod (edited December 28, 2000).]
Old Dec 29, 2000 | 11:30 AM
Vader's Avatar
FG,
What year is the car? If you have a 90+ car and are still using the stock 305 PROM, I think you've found the biggest part of the problem. With your mods list, you'll probably even have trouble with the stock 350 PROM, but it should at least be better than the 305 programming.
The "sucking" sound you are hearing is very common to Edelbrock/BBK throttle bodies. The IAC air passages are not muffled as well as the Rochester TBs, so the noise will be there forever - get used to it.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 29, 2000 | 12:13 PM
Blade's Avatar
If it's a LOUD sucking sound it's most likely because your IAC valve is stuck open all the way. I'd try to reset the IAC first (following the procedure listed in the technical articles section) and that will probably take care of that. As far as stalling... is the idle pretty decent when it does it ? Is it TOO low ? The 02 sensor has nothing to do with it since the ECM ignores it until the engine gets warm and goes into closed loop. You would definately need a custom chip for that engine. A 305 chip will hold it back big time.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 29, 2000 | 02:49 PM
FormulaGod's Avatar
Its an 88 with MAF. yeah, i know its definetly time for a custom PROM. Blade, your idea sounds right about what may be happening to the iac..thanks.!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
