TPI on 350 carbed or TBI... HP/Torque change, quick question...
Old Jul 25, 2007 | 03:27 AM
roguecoxnet's Avatar
Okay so I'm stuck! I've searched and found nothing. I want to put a 90-92 TPI 350 with Speed Density in my Jeep. The problem is I can't find one. I've searched salvage yards within 200 miles. Nothing.... BUT I can get a TBI 350 or Carbed 350 and get a TPI setup on EBAY... My question is when putting TPI on a carbed or TPI engine, does the HP go up dramatically? If so how much HP/TQ (estamating) & what would be the best engine (year) to put a TPI setup on to get Torque and good HP. Remember I've got a jeep, no need for speed just power...
I've really tried searching but coudn't find anything. Any help would be great. Thanks!
Old Jul 25, 2007 | 06:12 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Re: TPI on 350 carbed or TBI... HP/Torque change, quick question...
just get the tpi/sensors/wiring harness/ecm off ebay, and get a 350 out of a late 80's early 90's truck.....
have the 350 rebuilt, rebuilt the tbi heads or put new heads on it, drop a mild camshaft in and put the tpi on top... should be good for about 220rwhp 320ft/lbs with the stock tbi heads
Old Jul 25, 2007 | 10:33 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The 90-92 SD TPI 350 engines are making 245hp (GM numbers). It's because of a better tune and better cam compared to the 225hp late 80's engines.
So make sure that if you get the late 80's block, you put in the new 90's cam.
One of our local members here in Austin TX has a full TPI system available. I think he even has the longblock. I'd have to ask him.
Lou
Old Jul 25, 2007 | 01:04 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
True, but if he's going to go that deep into the engine, might as well opt for a tad better of a cam over the stock 90's one....
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
