Need help removing plenum from runners...
Old Dec 29, 2000 | 01:39 PM
Dan87IROC-Z's Avatar
What kind of a tool do I have to use to un-do the bolts that hold the plenum and runners together. Are they allen head, bristols, what??
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 29, 2000 | 01:41 PM
theformula's Avatar
Torx
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
Old Dec 29, 2000 | 04:53 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
It is a T-40 or 45.
87 Z28 305 TPI, Auto, 2.77, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47.
Old Dec 30, 2000 | 06:33 PM
How much do a set of those usually cost??
L98 TPI 350 (5.7L)
Old Dec 30, 2000 | 09:38 PM
ghostkilla2179's Avatar
i got a set of t20-t45 from pep boys for about $10...
Old Dec 30, 2000 | 10:32 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
You going to port your plenum??
If so, check out: http://www.isthq.com/~dan/efi.html
There's a couple of pictures on there that show come of the mods you can accomplish with a die grinder.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
